Sep 8, 2014 #1 D daddio4048 Veteran Member Jan 21, 2013 823 Valdosta,Ga. F.S. GM headliner material Headliner material for sale.Pre-cut & ready to install. $25.00 plus shipping Last edited: Sep 9, 2014
Sep 9, 2014 #2 W weiland2 Member Sep 16, 2010 83 Dubuque, IA Is this for a '73? Looks to be the same as they offer online. If so, I'm interested (a.k.a. dibs!).
Sep 9, 2014 #3 T tlongwel Veteran Member Jul 11, 2012 324 Ohio Put me next in line if this will fit a '73. I will ask for shipping if weiland2 decides he doesn't want it.
Sep 9, 2014 #4 1971CamaroGuy LS Swapped 1971 Camaro Oct 31, 2004 3,881 Wasn't 73 a changeover year between bow and 1-piece headliners? I guess it depends on what you currently have if it will work. I think 1-piece headliners where the same through 81. So that material would work.
Sep 9, 2014 #5 D daddio4048 Veteran Member Jan 21, 2013 823 Valdosta,Ga. This came in a box with my 79 I purchased.I don't know if it will fit a 73.If yours has the backer board I would say it would probably fit.My buddy has a 73 & I will check & see if it's the same.
Sep 9, 2014 #6 W weiland2 Member Sep 16, 2010 83 Dubuque, IA Good deal, much appreciated! I'll wait for your reply.
Sep 9, 2014 #7 D daddio4048 Veteran Member Jan 21, 2013 823 Valdosta,Ga. This headliner material is for years 74-81.
Sep 9, 2014 #8 W weiland2 Member Sep 16, 2010 83 Dubuque, IA I'll have to pass on it then. Thank You for checking!
Sep 9, 2014 #9 MotionClone Veteran Member Jan 20, 2014 1,479 away from the crazies PM Sent. I can use it
