chknbone
So let's say that when someone took off the upper control arm on their '81 that they didn't know that the cross shaft mounting bolts were pressed in and they use an impact wrench to remove them which either stripped the groves on the bolt or in the holes on the mounting bracket (can't tell which just from eyeballing it). The result is that the bolts can now be "pressed in" by hand and don't have enough bite to hold by themselves when tightening down the nut. Not an issue when mounting because I.....I mean "the guy who did it"....can just rotate the control arm up for access to hold the bolt heads secure. However, I see it as a big problem when taking it to get an alignment after the entire front end has been put back together if the nuts ever need to be backed off and re-tightened to add/remove shims during an alignment...
Would doing a tiny spot weld be the way to go or is that just asking for another headache for someone else down the road? Would something like JB Weld work?
Thanks.
Thanks.
