K1ng0011
I am installing a 4 speed transmission into my 72 camaro. This is my first time installing any manual transmission. It is an NP440 or MY6 transmission. Basically a GM version of a Chrysler A833. The first question I have is finding neutral on the transmission itself. From what I have read normally neutral for the studs for the shift forks need to be straight up and down for all three. However I cannot move the first and second gear shift fork when the reverse stud is straight up and down. I have to pull it back and then I can move the first and second gear shift fork out of neutral. I think that is neutral for this particular transmission. Does that sound right? The second issue is with the Hurst shifter itself for this transmission. I have two of them. When I have both of them out of the car in a vice I cannot get one of the shift arm levers on the bottom to move on both shifters. Its like I cannot find the gear to move that lever for some reason. I did verify when I had them in a vice the reverse pin was not contacting the vice itself. I am puzzled how both shifters have one gear that I cant seem to find.
