Pressure for Nitto Drag Radials?
  • Thread starter AllGoNoShow
AllGoNoShow
2,596
Rochester, NY
I have some 275 Nitto Drag Radials, what should I use as a baseline to start at tire pressure wise? What kind of burnout should I do and how long should I hold it? (This is my first time without street tires) Previous best was a 14.7@96 with 2.3 60ft time so its not too much power.
Also what do you guys use to adjust tire pressure? I have one of those cheap compressors you plug into the cigarette lighter, will this do?
Thanks
PONYEATER
2,796
Arlington, WA
Start with 20lbs do a good burnout and if it spins drop the pressure in 1lb incriments until it hooks. Do not go below 15lbs. also mark the tire to the rim to make sure it doesn't spin. YMMV
Arron Spitzer
1979 Camaro
"basicly stock but pretty fast for a old street car"
