Jun 8, 2015 #1 tims78camaro Veteran Member Aug 6, 2008 610 louisville ky my rpm gauge im not sure it hook up or what but it go all the way around. what does it hook to and what hooks to it? pictures would be great help
Jun 8, 2015 #2 CorkyE Veteran Member Lifetime Gold Member Nov 4, 2004 12,631 Ringgold, GA Are you saying the needle makes a complete revolution? If so, then it's connected and you have a problem with the tachometer itself.
Jun 8, 2015 #3 RS1979 Veteran Member Lifetime Gold Member Jun 18, 2013 4,055 Memphis, TN ^^^My thoughts too
Jun 9, 2015 #4 tims78camaro Veteran Member Aug 6, 2008 610 louisville ky yes the needle go all the way around when you start it or just turn it over without starting it . doesn't gauge mark repair them?
Jun 9, 2015 #5 CorkyE Veteran Member Lifetime Gold Member Nov 4, 2004 12,631 Ringgold, GA Yes, Gauge Marks (Daniel) repaired mine that was doing same thing. Not saying I had same issue you do though. It's best to call Daniel at phone number listed under contact tab on his web site.
