steering colum demolition
  • Thread starter 70 Z UC
70 Z UC
1,588
Los Banos, Ca, U.S.
I've got the thing stripped down past the key housing outter shell. How do you remove the rest? I don't see anymore bolts. I've got to take it all the way down to tighten the tilt nuckle, and remove all the sand from the previous owners blast job.
[URL=http://www.ncmaracing.com
70 Z UC
1,588
Los Banos, Ca, U.S.
ARGGGGGGGGGGGGG, I hate special tools. Do they press out (Can I use a slide hammer with threaded insert?)
LS1 1971
1,099
Terrebonne, OR U.S.A.
<font face="Arial,Verdana" size="2">Originally posted by 70 Z UC:
</font>
Yes they are a press fit, you should be able to use a slide hammer if that is all you have. They realy aren't held in by much pressure, so a couple of pulls and they should come right out. The bottom does have another spring, so just be aware of this when you are taking the pins out.
