B.M.
I dont think it actually has anything to do with the engine,but on my 81 there is a round thing that looks like a ball with a vacum line and another line coming off it right above the a/c box.Can anybody tell me what this is?
I took the a/c out so do i still need this then?It is right in the spot i want to mount my msd box so if i dont need it there anymore that will work out great.CorkyE said:Yep, vac reservoir for the heat/air system. It holds vacuum so you can change from heat/vent/air condition when under load and vacuum is weak.
z28rod said:vac reservoir for the heat/air system controls, leave it so your controls work......
Twisted_Metal said:^+1
I think it's kind of fun to find cars where these have been removed.
When you hook up the vacuum line again..... Junk comes flying out of the dash where no air has been blown for a decade!
Even though the owner has a mess to clean up... They are usually thankful to have some control about where the air blows!
