BBC Heads need info
  • Thread starter 1970 Z28
rscamaro73
www.mortec.com
They used them on cars and trucks....lots of them
theflash
11,044
Podunk, CT
according to mortec.com:
336781.....73-85...oval...OPEN...454, 118cc chamber, 256/114cc ports
7
73454
Guest
781's are one of the best flowing oval ports made. There are several versions, so the only way you will know the chamber size is to CC them.
pdq67
BANNED
Jul 26, 2001
10,496
Columbia, MO, USA
Just match piston dome shape and quench distance and headgasket thickness such that you create the CR. you want is all.
I use the ROSS Racing Pistons CR. Calculating site.
I use a stock piston down in the hole of .025". Then try to shoot for about 9.5 to a schosh under 10 to 1 CR., (depending on the intake valve closing point for a good Eff/Dynamic CR. of about 8 to 1), and a from .035" to .045" quench distance.
Hope this helps..
pdq67
