GREGS396
I just had the 396 for my 68 Impala rebuilt, completely stock except for a mild cam. I fired it up for the first time today, and was going through the break-in procedure. After 10 minutes, it started to run hot and I had a few leaks from the upper and lower hoses. I was just thinking that I hadn't tightened them up enough, but a friend of mine was quick to point out that he thought I was running the wrong temperature thermostat. The car has A/C, and the listing called for a 195. I went with that temp, and he's saying he had similar issues, and had used a 160 degree. The capacity of the cooling system is 23 qts, and I had 20 in it prior to startup. I even bled out the air by removing the heater hose from the intake. I'm not sure if the engine still devleoped an air pocket, or if I'm indeed running the wrong temperature Thermostat?
Any input is welcome.
