Door upper trim studs.
  • Thread starter BP80Z28
BP80Z28
1,160
Plymouth Mass
Hi Does anyone have the the measurements for the studs on the top of the door that hold the clips for the stainless steel trim.
CamarosRus
9,309
Auburn,WA (between Sea & Tac)
Show me PICTURES
how 1981 Door Trim is same as Z21 Style Trim Moldings from
1970-72 Camaros...................
PC70
485
I have the original doors off my 70. They are not worth repairing however the studs and in completely different spots . I think they both have 6
Studs . Been a while simce
I looked
35,788
Bloomington, MN
The Z21 door trim pictured above looks just like the Z21 trim which was on my 80. (I deleted it but still have it in storage.)
Drip rails were different on the early models (stainless steel).
The upper door reveal molding (Z21) was always stainless steel. (I've never seen a rusty one.)
The only critical measurement for those studs is from the top edge of the door.
The spacing between them will vary from car to car.
Only the end studs had to be "close" to where they needed to be for the clip to fit properly and hold the ends tight.
The trim piece had the same inside dimension (where the clips fit) it's whole length so the studs only had to be spaced "in the ballpark" of every 6-10" apart to secure the trim from one end to the other.
Measuring and comparing any one door to another will almost certainly produce different measurements between the studs.
Even for the same model year and the same assembly plant.
They are called "Nelson Studs" and it takes a special welding attachment to replace them.
There are screw-in replacements available to replace the welded studs. (Same pieces as were used for window trim.)
BP80Z28
1,160
Plymouth Mass
Show me PICTURES
View attachment 208511View attachment 208513View attachment 208515View attachment 208517View attachment 208519View attachment 208521View attachment 208523View attachment 208525View attachment 208527View attachment 208529View attachment 208531View attachment 208533how 1981 Door Trim is same as Z21 Style Trim Moldings from
Thank you! The position of the stud looks like the top of the clip is flush with the top of the door skin.
26,349
Southern Ontario Canada
Stud distance varied as mentioned depending on who was installing them. I guess they didn’t have a jig for the L/R distance, only the vertical distance.
