Unfrozn
I'm in the process of detailing my engine compartment.
I have removed everything I plan to before degreasing and pressure washing including hood, radiator, inner fenders, brake booster, fan shroud, fan and pulley, alternator, and heater hoses. Bagged and taped up the carb and distributor. I will be replacing most of the wiring anyway and the spark plugs, temperature sending unit, wires and cap/rotor.
My issue is that my engine block is starting to peel and chip in a few spots. The detailing job will just look half ars if your still looking at chipped paint on the block. I want to paint the block but don't want to have to pull the engine to do it. I realize I can't cover the whole thing like it was if it were on a stand. But my car isn't a show car and I'll be satisfied if I can just get the paint that's on there to look better and not be two tone. The paint is already blue to match the body and I don't want to change the color, so I was hoping I could prep it as best I can with the engine in the car, take the headers, water pump and manifold off and tape the heck out of everything else and on the surrounding frame/suspension/firewall...then paint away to cover as best I can from different angles. I know the trick in using a paper towel tube to aim the spary in tight areas.
Lazy man's way I know but am I that far off? Anyone else deal with this?
