We've discussed this ad nauseum here, and Brian Callahan has his most excellent weight database with lots of info. However, I was reading this article last night- Hot Rod's GM crate motor shootout.
(5MB file)- http://www.gmperformanceparts.com/_res/pdf/MagazineArticles/49917_eprint.pdf
Take a look at the race weights for the different combos. What struck me as most odd was that the smaller-than-expected different in the engines.
LS7 (alum block, heads)- 3420 lbs.
LS3 (alum block, heads)- 3334 lbs.
LS327 (iron block, alum heads)- 3386 lbs.
ZZ4 & ZZ383 (SBC, iron block, allum heads)- 3360 lbs.
ZZ427 (iron BBC, alum heads)- 3520 lbs.
I'm most surprised that the LS7 is so much heavier than the LS3. I didn't think the dry sump stuff would add that much weight. I'm also very surprised that the ZZ4/ZZ383 SBC is only 25lbs heavier than the LS3, and that the LS327 is actually 25lbs heavier than the standard SBC.
These engines are missing most accessories, of course, but they're all missing them, so the comparison seems pretty valid.
Thoughts?
Thoughts?
