Domobomb
I see you've upgraded the coil and cap...with an otherwise stock HEI? The module is what keeps the coil saturated with spark. If you're still running the stock ignition module...well they tend to lose a bit of energy above 3800 RPM. Especially done by 5000.
It could also be lack of fuel....and it may very well be a combination of both issues.
Yes, ignition is all stock except the cap and coil which was causing EMI noise on my vette's efi so I put it on my Camaro.
How old are those heads? Probably not, but weak valve springs will cause problems like this with a radical camshaft. Weak fuel supply will sometimes cause the engine to pretty much shut off, then catch, repeat. Lean in the secondaries might actually cause this type of hesitation too, let off the gas just a bit and it runs better sometimes.
I built the heads/valvetrain 2 years ago.
Check the float levels. If they are set to low the engine is going to be starved for fuel at the higher RPM. Check all the basics first before you go crazy. Just my .02 cents
Thanks I'll do that. I did set the float levels properly a few years ago though. Maybe they need adjustment again.
With a 60' of 2.248 I suspect gearing is the issue at hand here . Do you know the rpm you were pulling crossing the stripe at the big end
Well, I can calculate rpm based on trap speed and assuming torque converting isn't slipping much. I get 3560 rpm at my trap speed of 82 mph. It sits at 3600 rpm like it's hitting a rev limiter almost the last 1/3 of the track.
The slow 60' time is more due to the street tires I was running - BFG Sport Comp 2 - 275/40R18, which I grabbed off my vette. Any brake torquing at all and it'll just sit an spin, so I had to launch at idle to control spin.
Man, that car is laying down, only gained 10 mph from the 1/8th to the 1/4. It must be fuel. The 1/8th mile time isn't bad, especially with the slow 60 ft time, but it isn't doing much after that.
You're right. The 18 second truck I was racing picked up more speed in the last 1/8th than I did. It was bracket racing though and the engine would die out the same way every time so I dialed in a 15.25 and won a few races lol.
what is your total timing set at out of curiosity? 36-38? too bad you dont have a visible fuel pressure gage. Is the carb fairly new? Are you shifting manually or letting the tranny shift itself?
Total timing I have not checked. Initial was set to about 12. Carb isn't new but always ran great on the street, very strong down low. But I never really stretched the cars legs on the street like I did on the track.
I have assembled a list of parts based on the feedback in this thread:
