Flex fan install
  • Thread starter riceeater
RePhil
1,300
Lorain, OH
You don't use a clutch with a flex fan. You need the right length spacer that positions the flex fan half in/out of the fan shroud.
Damon
12,939
Philly area
Agreed. Either clutch with stock (fixed pitch) fan or flex fan mounted direct, not a combination of the two.
Bolt pattern between the stock fan and flex fan should be different enough that it's obvious what will work with what.
theflash
11,044
Podunk, CT
You will also need to find the right length bolts too once you find the correct length spacer. Three hands installing these helps too. ;)
hhott71
R.I.P 11/19/18
14,377
Joplin Mo. 64801
You NEED the Clutch and the Original fan.
NO FLEX FAN!!
It eats HP and reduces Cooling,,, Everything you DON'T want!
Sell trade the flex fan to an idiot furd dudge owner, you'll be better off.
