headlight switch wiring
  • Thread starter neiln
neiln
335
uk
hi,
just downloaded the wiring diagram that includes the headlight switch,
i can't work out which wire is which,
it looks like there's 7 wires,
can anyone tell me which is which, please,
i want to take it for it's test tomorrow and the switch is knackered, i've 2 flick switches and a couple of relays and was gonna quickly wire it up so i can get it through it's test,
thanks guys,
neil
neiln
335
uk
hi,
am i right in thinking:
black - ground,
dark green - instrument panel illumination
orange - permanent live
red - permanent live
white - dome light and door switches
brown - side lights
yellow - dipped headlights
if this is the case i can get away with only 4 wires, ground, live, side and dipped,
can anyone confirm please,
neil
calflan
394
Marana, Az USA
Your profile says '80, so I assume that's what year wiring your asking about ?
black - ground - correct (common grnd for several circuits)
dark green - instrument panel illumination - correct (goes to fuse for instr lts.)
orange - permanent live - fused for tail then live power
red - permanent live - correct
white - dome light and door switches - correct
brown - side lights - rear lts. & side lts.
yellow - dipped headlights - power to Hi/Low beam switch
[This message has been edited by calflan (edited June 24, 2003).]
neiln
335
uk
thanks a lot for that,
not quite sure what you mean by:
is this so the stop lights can flash as indicators???
with me being in the uk, the indicators have to flash independatly of the stop lights,
thanks,
neil
