Make 350 powerful without making it a 383
  • Thread starter Tyfraley
ManwithNoName
165
Lancaster, PA
I just had my 355 dyno'ed at the shop today & it put out 432hp/440TQ vortec heads at 10.95:1. I know you're going with he 383 but you can still make really good power with a 350.
hhott71
R.I.P 11/19/18
14,377
Joplin Mo. 64801
I wish these Dyno'd engines or chassis Dyno'd stuff also make it to the strip.
A few passes down the track is easier than Dyno pulls. And a hell of a lot more fun!
And of course post back here with all the numbers.
ManwithNoName
165
Lancaster, PA
Mine will make it to the track eventually....I just have to get her back on the road first.
Tyfraley
56
Fort benning
Sounds good, i have a new edelbrock performer intake. The black powder coated one. I was thinking about just getting edelbrock heads to compliment the intake manifold. The machine shop told me it would be 475 for all the machine work plus acid wash. But then they said if i wanted them to put everything else in like the crank...it sould cost an additional $350. I may see if the auto skills center on base will help me put in the crank, pistons etc. i really wanna learn this stuff myself. So i can bettter skilled beyond rotatig tires and changing starters.
hhott71
R.I.P 11/19/18
14,377
Joplin Mo. 64801
It really is as easy as rotating the tires.
You just need the Right tools.
Tyfraley
56
Fort benning
383 stroker kit
So I got my 383 kit in the mail today here it is (cost = $1199)
This Kit Includes.
1 Set of H860CP30 Federal Mogul Pistons Flat Top Approx Compression Ratio (10:1 With 64cc)
1 Scat/PBM 70002 Cast Crankshaft 3.750" Stroke 2pc seal
1 Set Of Scat Or Eagle I-Beam Floating Rods With 3/8" Cap screw Bolt (this is an upgrade from the original rods that come with this kit)
1 Set of 2M139.030 Hastings Moly Std Tension Rings
1 Set of Clevite CB663p Rod Bearings
1 Set of Clevite MS909p Main bearings
1 Set of Dura-Bond CH8 Cam Bearings
1 Fel-Pro Complete Gasket Set
1 Melling M55HV High Volume Oil Pump
1 PBM 700 Dual Row Timing Set 3 Key.
1 Erson E110040 Performance Camshaft Hyd. (.465"/.488" Lift 224* / 234* at .05 Duration 112 L/C) (Cam can be substituted for for different applications)
1 Set PBM HA817 Hyd. Lifters
1 Set PBM 3000 Hyd. Valve springs ( 1.250" O.D. 110# @ 1.700" 300# at 1.250" up to .500" lift)
1 Set PBM 501S Chrome Moly Retainers
1 Set PBM 205 7 Deg HD Keepers
1 Set Pioneer PE100B Freeze Plugs
orkin
259
Texas
I'm also stationed at ft Benning. unless they got a brand new one, don't trust the torque wrenches at the skills center! they are precision tools being used and abused by unskilled hands. most parts stores will have a cheep one for $30-$40. probably only good for 2 or 3 rebuilds then get a new one
CNC BLOCKS
1,656
NORTHEAST
Built one with vortec heads a few years ago single pattern cam 432 horse and 463 on the torque.
This is 355 that just came of the dyno a 2 weeks ago. Dart 180 Pro 1 heads, HYD. roller cam .570 lift, Mahle flat top pistons, zero decked and left the VIN numbers on the deck, Morel lifters, Scat 6 inch rods. Champ pan & pick up, HP 600 carb. 1.5 roller rockers
Dynoed at 459 horse and 455 torque
CNC BLOCKS
1,656
NORTHEAST
This Kit Includes.
Most rods unless they have been ground are not considered a stroker rod and you may have cam to rod clearance problem. Is the cam a small base circle cam?
Those cam bearings are a stock replacement if you ever decide to with a bigger cam and better springs those may not handle the task, The CHP-8 is considered a performance cam bearing.
Good luck with your build.
