Hi Everyone,
So I am going to purchase a floater rear that is based on a ford 9" rear in that it uses a 9
ford center section , I am buying from Speedway Engineering , and he wants to confirm the size and where the spring perches will go , so I found this info here
The following dimensions are consistant across all 3 style rear ends.
- Axle tube flange to axle tube flange: 55.25"
- Between centerlines of spring seats: 45 3/8"
- Axle shaft length: 30 5/32"
the Axle length is not important , however, I just need to be sure he has the right numbers, also, I think I really also need to know the finished size, the size from side to side, where the tires bolt on, is that the 62.5 that I see also ? Is that the Flange to flange size? On a side note, just to confuse me more a friend said, make sure the center is the correct offset?? I thought it was in the center? Right? Anyways need the wisdom of the site, and also if there is something else that I should be sure that they know so that what I recieve after Weller racing puts the brakes and lines and center section in , it will be bolt in ready , HAA HA
