neutral start switch fix: shift works SW653
  • Thread starter need-for-speed
Damon
12,939
Philly area
Apologies if I missed an earlier post but what problem are you trying to "fix"?
Most aftermarket shifters already come with a Park/Neutral safety switch (and reverse light switch) in them.
I'm guessing you're looking to use a factory floor shifter but ditch all the linkage that goes back up to the column to work the switches? If so, that looks like about as good a solution as you're likely to find. I'd just wonder about how long those switches will last outside the passenger compartment getting dirt and moisture thrown up on them.
81BirdMan
785
Outside? Looks like it mounts to the shifter (inside the console)?
Damon
12,939
Philly area
Sorry, their website was a little unclear where it was mounted. I thought they were putting it down on the shift arm of the trans. If it's right on the side of the shifter then you should last a good long time.
CorkyE
12,631
Ringgold, GA
I've been looking at these, going to install a 700R4 in the future. I noticed the same thing where the web site show that switch at both locations. Guess I'll find out for sure. If down on the transmission itself, I should be able to put some type of wrap on keep the road crap off.
need-for-speed
1,683
Conroe, TX
My question is how it is wired. I did email them and they said I could run the wires up to the switch on the column. I think I can figure it out based on that, but I would love it if someone had already done it and had pics and step by step LOL.
need-for-speed
1,683
Conroe, TX
you will LOVE the 700. with that low first gear, you can burn rubber at will.....
need-for-speed
1,683
Conroe, TX
Correct. When I installed the 700R4, I kept the OEM shifter and installed a Shiftworks conversion and ditched the linkage.
need-for-speed
1,683
Conroe, TX
One of my goals is to get my backup lights working again when I install the SW653. Can someone tell me how to access the OEM switch on the column or is there an easier way to access the wiring harness for that ?
