Our youngest son wants to build a "real" motor for his 83 S10. It now has a bone stock 350 small block in it, 2800 stall converter on a TH350 and 3.73:1 rear gears.
I have a TH400 with a B&M 3000 stall converter to go in place of the TH350.
He wants to narrow a 8.5" ten bolt to put in place of the 7.5" ten bolt, put Moser axles with c-clip elimators, and probably 3.73:1 gears (again).
As for an engine, we will most likely build a 355 (.030" over 350) as we have a good forged crank and a set of Speed Pro hyper pistons and moly rings for it. We'll buy a good set of rods that'll complete the rotating assembly.
I want to buy him a good set of heads (at Christmas). I have a couple of different Holley carburetors for it (780 cfm dual feed double pumpers) but not intake yet that I think will work well with his goals so I need input on a good intake for it. I've looked at the Edelbrock head and intake kits but I'm not sure about them. I'm leaning more towards Canfield iron heads and a Edlebrock air gap intake.
He wants to run a roller cam. I'm leaning towards a hydraulic roller cam but haven't decided on which brand. So, given the above information, what cam brand and which of their hydraulic roller cams can you suggest?
Any and all ideas will be appreciated.
