Someone wanna dyno this for me?
  • Thread starter CamaroMan79
CamaroMan79
5,618
Selah, WA
Anyone have a dyno program?
383
Block: 350
bore: 4.030
stroke: 3.75
Rod length: 5.7
Heads: Edelbrock performer RPMS(Int/Ex, .100"-.600")
67/58 130/108 183/144 226/169 229/175 232/182
Compression: 9.9
Carb: 770 w/ vaccum secondaries
Intake: RPM Air Gap (Dual Plane) w/ 1" carb spacer
Headers: 1 3/4" mufflers, and electric cutouts
Cam: Crower Hydraulic flat tappet (234/244@.050, .498"/.513" lift, 110 lobe, 106 centerline,
Rocker arms: Comp Cams Pro magnum 1.52 ratio
Ignition: Mallory Billet HEI
Lowend
Administrator. .a car, a man, a maraca.
17,967
San Jose, CA, USA
Run the 64cc heads with flattop pistons , it will bump the compression up to more like 10.6-1 and the engine will be putting out more in the low-mid 400HP range
CamaroMan79
5,618
Selah, WA
I downloaded the virtual engine dyno and these are the numbers I came up with
