Turn over, no start.
  • Thread starter 78BBODY
MChamp
418
north carolina
^ yeah I'd make sure wires are correct before getting into internal issues. 5&7 can easily be incorrect. Then maybe pull all the plugs again and see if anything looks off. You'd have to do alot of cranking I'd think to whipe a lobe..
78BBODY
49
Manitoba, Canada
I'll look next time I get a chance. Also going to pull the valve cover to see if the valve is indeed moving. That should tell me if it's gone.
78BBODY
49
Manitoba, Canada
Finally got it going 😅 Got the car out of storage, took everything apart, and with a clear mind, put it back together, and thankfully everything is running fine now 👍 I think it was just a tooth off, and because the area around the vacuum advance is very tight, I had put the distributor in a place where I couldn't adjust properly 😑 Thanks for your help you guys!
