jjs3788
Turn Signals +Headlights =Me Going Crazy
I have a 72 with all factory wiring under the dash. Its all in really good shape. My problem is both signals on the dash work perfectly until you turn on the headlights. Once tou turn the headlights on both dash turn signals light up. If you put a turn signal on while the headlights are on, they will flash but as soon as you turn the signals off, the one that was flashing goes back to steady on again. Everything works great independently of each other, its only when you turn the headlights on that the dash indicators wanna stay on unless they are flashing. I thought maybe the harness thats bolted to the firewall and goes up to the guage cluster and headlight switch might have rubbed thru and when the grey wire that feeds the dash lights got power it was feeding the light and dark blue wires for the signals. So i took the wire harness out and removed all the tape and the wires look fine. All the pins in the harness connector look fine, nothing bent or touching. I can not figure out why the signals are getting power when the headlights are turned on. This problem is confined to the dash. All exterior lught function properly. Any ideas ?
