Chaindrive
I'm trying to tackle our window regulator and door panel problems. After I finish making one good regulator out of two or three bad ones, I need to replace all the felt pads on the window guides.
I'm pretty sure our 73 should have 3 guides. As it is (driver side door), there is one guide in the middle and one in front and a slotted hole in the rear position that shows evidence (scratching) of having once had a third guide.
The front guide has no felt at all and looks more to be for mounting the door panel than as a window guide. The middle guide has worn out felt and the window is scratched as a result. The rear guide is missing, but I have a replacement.
All of the felt in various locations on the window hardware is worn through. I have seen "kits" on ebay for $25 plus shipping for just the felt pads for one door. That seems pretty outrageous and I was wondering if anyone has found a better/cheaper replacement?
I was thinking of using the fuzzy side of some heavy-duty self-adhesive industrial velcro. Has anyone tried this or something similar?
Also, is there a sticky anywhere about adjusting the window glass properly? The idiot's guide to getting windows and/or doors to align and seal properly?
