The number 1 cause of vibration is failure to prepare the crankshaft for installation. Each time the converter is installed without sanding out the crankshaft rust, removing the paint from converter pilot and adding a little grease, the converter may be drawn up crooked with the first bolt. This may cause the converter to run-out and usually ruins the pump bushing.
