ULTM8Z
Well the transmission is out.... new record for me... ~2.5 hours.
Nothing obviously wrong anywhere that I can see...
The crank pilot seems mostly clean. Maybe a light steel wool abrading to get rid of some minor surface grime, but other than that seems fine. Dowel pins and holes look good.
Flexplate doesn't show any obvious cracks or damage.
I also checked the end play on the crank. Got a dial indicator on the back of the crankshaft. Took a small crowbar and carefully pried it forward on the crank pulley. Zeroed out the dial indicator, and using a flex plate bolt on the back of the crank, I pried it backward. Did that about 5 times and the best I could get out of it was about .004 to .005. Rotated it a couple of times too to make sure it wasn't binding or anything. But that seems within spec from I'm reading online.
The reality is this engine is smooth as an electric motor when the converter was disconnected from it, so I'm not really considering the engine to be suspect anymore.
Any rate, I'll take it into my transmission guys this week and see what he says I guess.
