Is there any market for TILT STEERING Column Assy ?????
  • Thread starter CamarosRus
72SS9681
323
Walla Walla, WA
Can you use the metal lock ring on a 1970 steering column on a column that has the newer style plastic locking i.e. 76 Firebird? And I assume my 70 steering wheel will work in the 76 column? I have both columns and before I tear both apart I just wanna make sure I’m not wasting my time
You can use the metal lock plate cover, but you need to replace the lock plate as well.
PC70
485
Ok thank you .
I just had some time to deep dive a bit. It appears there is a non tilt and tilt lock plates. My original 70 is non tilt and the 76 firebird is tilt. Can I use the firebird lock plate?
I don’t mind using the plastic lock plate cover if it will work with my 70 wheel. The column is very tight so I don’t wanna go tearing the whole thing apart. It’s a bit confusing to me
72SS9681
323
Walla Walla, WA
Camaro and Firebird lock plates are the same, sorry should have mentioned the plates are different for tilt and non-tilts.
Can't say for sure on the 70 wheel working with the plastic cover but I would be surprised if it didn't. Someone here should know.
PC70
485
Ok cool. I’ll hold off a bit and see if someone else knows. Thank m not in a rush just picking away at small things as I go along .
