My 1979 Camaro project
  • Thread starter KEVS79
KEVS79
2,463
GLADSTONE, MO
Well, I got my "inner frame rail" all fab'd up. I actually turned out pretty good considering my very limited welding skills:eek:
KEVS79
2,463
GLADSTONE, MO
Well, I got the frame rail tubing partially installed. I think it is going to work out ok. It will give is some strength under the sheet metal I am going to wrap it with. Since there was some good metal left on the sides, I spot weld it to those, the floor and the torque box.
KEVS79
2,463
GLADSTONE, MO
KJZ28 said:
Your tail panel looks a lot like mine. I just ordered a replacement panel.
Those tail lights look amazing!!
I thought about ordering a new one, but will probably just patch mine and see how it turns out.
Thanks for the compliment on the lights......it was a very simple project, but will make a big difference.
KEVS79
2,463
GLADSTONE, MO
I did some more work on the frame rail today. I made a piece to cover the back part and got it welded on. I will probably put a light coat of body filler over it before I put the undercoating on just to smooth it out.
I made a template from the old one and cut it out and bent/welded to shape.
KEVS79
2,463
GLADSTONE, MO
olstyle said:
Looks good Kev, nice work.
Thanks, I cant wait to get to the point where I can start refinishing the underside. I am only "allowed" to work on it about one day a week, so it is coming along VERY SLOW.
BTW, yours is coming along great!!! At the rate you are going, you are going to be done pretty soon.
olstyle
8,490
Crestwood IL.
Even very slow is better then nothing ;)
